Fuel pressure..
Old Jul 15, 2004 | 01:34 PM
TFGG Motorsports's Avatar
Fuel pressure..
I know this has been beat to death but I didnt find an answer like I was looking for...
Start the truck this morning and the fuel pressure gauge decides to work...
14-15 PSI at idle, I'm happy as a clam
so I start driving it, the psi goes down as the engine warms up till I pull into the shop and im reading 11psi at idle... it never went below 5psi at wot, so I think that is good
but I did notice that when I was heavy on the brakes, I could get the gauge to read 14psi
and I found that I could vary the PSI over idle by how fast I was stopping
is the 15psi at idle in neutral?
Old Jul 15, 2004 | 03:29 PM
Update time...
Gauge runs normally 11PSI untill you do some full throttle passes then it sits around 10psi
also at 2900RPM the gauge gets down to 3.5
Old Jul 15, 2004 | 07:55 PM
dodgediesel4x4's Avatar
With those readings, make sure everything is hooked up correctly. If so, and I'm guessing it is, then it sounds like your lift pump is shot. You should not drop below 7-8spi under wide open throttle. Check to see if there are any codes being set on your truck. If your lp is shot, then its only a matter of time before your vp-44 dies on you also. If you don't pass the flow test (I can't remember the specs), then its time to replace your lp. Hopefully you can catch/delay the problem by just replacing the lp. If your pressure is still low, then say hello to a new fuel pump.
P.S. Please fill in your signature so we can have a better idea of what you are talking about.
Old Jul 16, 2004 | 12:48 PM
FastSS's Avatar
er sorry... forgot to fill in the sig at work... its my truck
I dont think my LP is quite done yet and I sure as hell cant afford to fix it at the moment... to my knowledge I have no codes
EDIT: if I bump the starter my LP makes all kinds of crazy noise... its messed up. Its not like the constant buzz, it changes pitch basically at random... its crazy
Old Jul 16, 2004 | 01:09 PM
Ryan's Avatar
Its time to replace it! The quicker the better.
Old Jul 16, 2004 | 01:11 PM
FastSS's Avatar
im trying to find my options right now... looking at the FASS or just another plain jane LP... I cant find prices anywhere (im still looking)
Old Jul 16, 2004 | 01:20 PM
BigBlue's Avatar
A lift pump from cummins shouldn't cost more than $150. You could do a Holley blue setup.
Old Jul 16, 2004 | 01:37 PM
FastSS's Avatar
Seems the forum is mixed on how good the Blues are... I've never been a big fan of holley pumps
does aeroquip or walbro make anything that will cut the mustard?
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
