Fuel pressure ?
Old May 17, 2004 | 10:52 PM
OldSmokey's Avatar
Fuel pressure ?
My bother has a 01 HO, we just took it to the dealer for a new lift pump, at idle its around 12 psi. the bad part is he can pull it down under 5 psi with a stock truck. His truck seems to have as much power stock as my 2000 with with my comp on setting one. Is it using more fuel that most high outputs do, a bad fuel pump, or would it be that the diprocol gauge not working correctly. Could it be that we didnt get all the air purged out of the lines. Thanks
Old May 18, 2004 | 08:36 AM
nitrousn's Avatar
if it is a fuel pressure gauge accuracy question i would get a master gauge and use the tap on the injection pump and compare readings. my 2002 with superchips 70 hp setting i run 12 to 13 at idle and most cruise speeds. wide open i am at 9 psi. this is a original lift pump with 42,000 miles.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
