fuel pressure
Old Jun 7, 2006 | 09:27 AM
turbo hoss's Avatar
fuel pressure
I just installed a fuel pressure gauge an wondered what the stock fuel pressure should be. My gauge reads 19
Old Jun 7, 2006 | 09:39 AM
crobtex's Avatar
Welcome to DTR!
That's pretty good, if you're running the stock lift pump. Mine never got over about 12.
Why don't you fill out your signature so we'll know a little more about your truck.
Old Jun 7, 2006 | 05:05 PM
Dr.Kayak's Avatar
I have had 2 OEM lift pumps they both showed 16psi at idle. I can get it down to 10psi or so at WOT. When the first pump started to fail at 80k miles the idle preshure droped to 10psi and I could get it to 0psi under light acceleration.
Old Jun 7, 2006 | 06:22 PM
phox_mulder's Avatar
That's a bit high for a stock 24 valve lift pump.
What vehicle do you have?
(if you fill in your signature, it will show up in the posts so you won't have to keep answering that question, it's in "User CP".
phox
Old Jun 8, 2006 | 09:44 PM
team's Avatar
is that 19lbs pre or post filter?
Old Jun 9, 2006 | 09:44 AM
cjthor's Avatar
I'm hopefully getting a fuel pressure gauge installed next week. Where is the best place to put it? The mechanic told me that they install them at the LP itself. What kind of pressure should I be seeing? Does WOT stand for WIDE OPEN THROTAL?
Old Jun 9, 2006 | 09:48 AM
crobtex's Avatar
The gage needs to be mounted DOWN stream from the fuel filter. Otherwise, you are not monitoring your filter.
Yes on the WOT.
LP pressures vary, but should be around 15/19 at idle and no less than 7/10 at WOT....at least that's what most folks say.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
