fuel leak
fuel leak
newsflash plumber can't find where diesel leak is coming from!!!! It appears to be coming from the backside of the block. Anyone have any ideas where it could be coming from???
If you put your hand between the fire wall and the back of the head you will feel another return line. The way I understand this line lets any fuel bypassing the injector tube or injector to return to the tank. This line comes off of the head and into a tee at the return fuel line from the injection pump. Mine started leaking. Gasket on the Banjo bolt was the problem.
Regards.
Gene
Regards.
Gene
Your lp is mounted near the back of the block behind the fuel filter. If you took out the mounting bolts for the FF you should be able to to a good visual inspection. If its not leaking at the fuel filter or lift pump then its gotta be the return line
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
