Fuel Filter...
Old Jan 31, 2006 | 05:04 PM
98ISURAM's Avatar
Fuel Filter...
Hey ive heard some guys change fuel filters every 10,000 miles and other various mileage incriments. Why are we supposed to change the filter so often? I bought my truck with 87,000 and now have 98,000 on her and havent changed it yet. Thanks for the help!
Old Jan 31, 2006 | 05:12 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Good preventative maintenance.
Catch the problem while it's still a little one.
Mine gets changed every other oil change.....~20,000 miles.
Never seen a problem, YET.
Old Jan 31, 2006 | 05:17 PM
P.J's Avatar
P.J
Change it.
Cheap insurance. I change mine every other oil change (10K miles).
Old Jan 31, 2006 | 05:19 PM
Shovelhead's Avatar
Should have added....DON'T buy the $47.00 filter from the dealer.
Go to Cummins and buy the SAME one for around $14.00
Old Jan 31, 2006 | 05:52 PM
Andy505's Avatar
I did that ONCE now I just get the fleetguard filter kits from geno's
Old Jan 31, 2006 | 07:09 PM
phox_mulder's Avatar
Every 10K here as well.
First change, right at 10K, the filter was filthy black gross yuck.
2nd change, at 20K, less gross, less black, less filthy, but still looked like it needed to be changed.
Each change it got less dirty looking.
Last change at 50K it hardly looked used at all, just dampened by the Diesel fuel, even after running a tank of B20 biodiesel a couple months ago.
Fuel pressure was looking lower than it should be, so I changed it anyway.
phox
Old Jan 31, 2006 | 07:54 PM
Dr. Evil's Avatar
Because diesel has so much crap in it - its not like gas.
Old Jan 31, 2006 | 08:00 PM
broncofreak2000's Avatar
I use Wix fuel and oil filters in my truck.
Old Jan 31, 2006 | 08:58 PM
Mopar1973man's Avatar
I buy Fleetguard filter from the Cummins dealer in Grangeville Idaho.
A for changing fuel filters... Its every 15K according to 2002 specs. I've only had to change one fuel filter early (6K miles) from a bad tank of fuel!
In the 15K time that filter will be BLACK I mean BLACK!!! So you more than likely starving your VP44 for cool clean fuel if your not changing it!
I had a pic of what a fuel filter looks like after 6K miles of bad fuel and a brand new one sitting besides it... Big difference!
Old Feb 1, 2006 | 09:03 AM
98ISURAM's Avatar
When you change the filter do you just have to make sure that the tank of fuel is full so you dont get air into the lines or are there any other precautions i have to worry about when i change it.
Old Feb 1, 2006 | 09:05 AM
2500WHITERAM's Avatar
i would agree with that to a point...if your dealer is charging 47.00 for the filter, find another dealer because hes a crook charging over list price !!!...lol...I am a dealer, and hes getting two-fold for that cartridge...lol
Old Feb 1, 2006 | 09:24 AM
I've never haerd of such...
Open up the filter and remove the cartridge.
Drain the filter of fuel using the drain valve.
Close vlave and reload filter with fresh fuel from a can.
Insert new filter.
Screw lid on.
Bump starter. It will run for about 25 secs...
Start truck!
Easy no problem...
If you do get air in the lines... Crack 1,3,4 injector lines and try starting. After it started tight the injectors back up. But I've never had to do this though...
Old Feb 1, 2006 | 11:10 AM
Andy505's Avatar
Insert new filter.
Screw lid on.
Start truck!
Easy no problem...
same here...works every time...I just let it run for a few minutes to make sure that there is no air in the lines..and there never is.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
