This is frustrating
Old Jun 20, 2007 | 09:40 AM
mini14's Avatar
This is frustrating
only on a cold start ie. truck sits all day or all night, it starts fine, idles good, take off and it has very little power and u almost cant here the engine running, drive around the blok at max 10mph, it clears up and is fine for however long u want to drive it. new fuel filter, has 7 psi , has no problems and runs great once warmed up.i disconnected the ez and nothing has changed. any help would be appreciated
Old Jun 20, 2007 | 09:54 AM
04ctd's Avatar
could the fuel psi regulator have a slow leak/pinhole that is letting fuel drain over a long time,
but the hole is so small the pump can keep the system full while running?
cycle the key about 3~4 times next time, that should run pump enough to refill the system, and see if this theory makes sense.
i had a a gas truck that leaked all fuel back into tank,
cycle key few times to prime the system fire right up.
Old Jun 20, 2007 | 04:44 PM
mini14's Avatar
thanks ill try it. allthough check engine light never came on, i bought a code reader today and got 0216 not looking forward to that. hope it is cauzed by another prob.
NoSparkplugs
Jun 30, 2011 11:38 AM
thxman
19
May 25, 2007 12:53 AM
dynobo
15
Apr 18, 2007 09:02 PM
plessm
13
Dec 14, 2006 10:10 PM
Riverman777
Oct 11, 2004 08:25 AM
