front wheel making noises
Old Jan 14, 2009 | 07:55 PM
captn.KIDD's Avatar
I have a noise coming from my driverside front wheel,it makes this noise whether i am in 4 wheel drive or 2 wheel drive.kind of makes a squalling,whiny chirpping sound under acceleration,and kind of metallic(tinny) sound under deaccleration. above 20 mph or so i am getting a vibration. anyone had this before?
Old Jan 14, 2009 | 08:55 PM
dozer12216's Avatar
Sounds like wheel bearing. Raise wheel off ground and shake for movement. More than 1/8 inch at outside of tire probablly indicates wheel bearing. Should be able to see.
Old Jan 15, 2009 | 04:40 AM
captn.KIDD's Avatar
Thanks Dozer! was't sure if it was the wheel bearing or maybe the front hub.once the weather warms up a little around here i will check it out,until then it can sit in the driveway.
Old Jan 15, 2009 | 04:44 AM
Fishin2Deep4U's Avatar
Could be the joint as well and sometimes the ball joints get so far out the joint will scream under the angle.
Dave
Old Jan 15, 2009 | 04:54 AM
98whitelightnin's Avatar
Arent the hubs and bearings all one assembly.
Old Jan 15, 2009 | 03:52 PM
captn.KIDD's Avatar
o.k. checked the tire for play.none at all tryed to pry the u joint around to see if there was any play in it,none there either.
Old Jan 15, 2009 | 05:08 PM
The u-joint can be shot and show no signs of play. Rotate the wheel, or have someone else do it with your head under there. Maybe the point of origin will rear itself.
Also, don;t forget sometimes the noises in the back sound like they are in the front.
Dave
Old Jan 15, 2009 | 05:15 PM
captn.KIDD's Avatar
sorry,forgot to tell you thats how i found out which wheel it was,had my dad come over and drive it while i listened to it from each side of the truck as he drove by. also when i had the frontend off the ground i rotated the tire,but no noise.really doesnt make any noise until about 10mph. or so, but definatly driverside front wheel.
The_Head
Jan 27, 2009 09:01 PM
NoSparkplugs
Dec 7, 2006 09:57 PM
Beeram305
Nov 19, 2005 01:56 PM
NoSparkplugs
Oct 8, 2005 07:50 AM
Sux 2B urTurbo
23
Aug 14, 2004 11:56 PM
