front main seal leaking
Old Jan 9, 2010 | 01:53 PM
upersleder's Avatar
have oil pouring out the front of my motor, its NOT the overflow vent deal. I have had it steam cleaned to better see the location because its blowing all over the place, but it seems like its either the front cover gasket or front main seal.
how hard is this to remove?
any tips i should know before beginning? going to do this project one day this week.
Old Jan 9, 2010 | 10:49 PM
x1phats10x's Avatar
mine is doin the same thing i jus replaced the front crank seal and now its leakin on timeing case that bolts to the block. the seal was a pain to change dont know what im gonna do about the case leaking
Old Jan 11, 2010 | 03:19 PM
SIXSLUG's Avatar
Are you sure its not the vaccum pump gasket between the PS pump and the vac pump?
Kurt
Old Jan 11, 2010 | 05:14 PM
Tate's Avatar
Changing the seal is pretty straight forward, just requires some disassembly. Having an extra set of wheels would be handy, because then you can buy the proper seal when you open it up. You might need one with a speedi sleeve if the crank has a groove worn into it. Cummins carries that seal and sleeve, among other places. Might need to come up with a way to install it though thats outside the box. If its anything like a sleeved rear seal, the seal and sleeve come assembled and can't be taken apart without wrecking the seal. We had to press the seal into the housing and then the sleeve onto the crank along with the housing.
Old Jan 13, 2010 | 08:02 AM
upersleder's Avatar
Kurt
I will check that, seems to be dripping more on the right (pass) side. if i did it i was thinking of doing the whole thing, timing cover gasket and all.
Old Jan 14, 2010 | 01:08 PM
SIXSLUG's Avatar
If its on the right side its probably not the vac pump then.
Kurt
Old Jan 15, 2010 | 04:35 AM
x1phats10x's Avatar
if its on the right side its proble your timing cover thats whats wrong with mine. mine is running from the top of the timing cover down to the right side and all over the bottom of my truck. i dont have to worry about anything rusting up for a while lol
Old Jan 20, 2010 | 10:01 AM
upersleder's Avatar
Well got it done, the timing cover gasket between the block and cover had a piece about two inches in length missing I did not have the time to rip the whole motor apart to fix it, so i cleaned it up really good with brakleen and wire brushed the area and used a special epoxy to fill the spot and fix the leak.
its nice to park in the driveway now, was parking in the dirt and had to walk!
Old Jan 29, 2010 | 09:03 PM
13FOX's Avatar
What is the the brand and type of epoxy you used? My girdle has a slight leak near the rear main and I need to patch it up until next winter when I'll be able to pull the motor and fix it for good. Thanks, Dan.
Old Feb 15, 2010 | 05:37 PM
upersleder's Avatar
it was a 3M product. two part epoxy which they fit in a mini gun to dispense it. not sure of the exact product number, sorry
boomerang
Jul 23, 2009 10:47 AM
Ceejmo
Dec 20, 2007 11:24 PM
Ilikebikes
Jul 7, 2006 04:26 PM
NoSparkplugs
Nov 1, 2005 04:59 PM
gotmuddy
Oct 16, 2004 02:54 AM
