front end noise
Old Sep 11, 2007 | 03:56 PM
stock659's Avatar
front end noise
Hi, I have a 2000 4x4 reg. cab, during off chamber bumps or dips in the road I hear a loud crack or poping noise on the drives side. I have recently replace the shocks with bilistiens and the stablizer shock. What needs relaced now? thanks
Old Sep 11, 2007 | 07:34 PM
dieselrob's Avatar
I would suggest either a balljoint, tierod end, or track bar ball joint on driver frame. Easy way to check, jack driverside up and wiggle the wheel back and forth, to check the tierod ends, or both hands on bottom and try to pick the wheel up, to check balljoints. If no movement that way, put the truck back on the ground, get someone to help you, have them start the truck and turn the wheel back and forth quickly while you look under the truck at all the mentioned parts above. You should see something moving that shouldnt.
Old Sep 12, 2007 | 07:14 PM
stock659's Avatar
front end noise
Thanks for your reply, the ball joints were checked recently they are ok. I'm thinking swaybar, but I'm not sure. If anyone has other thoughts I would appereciate it. stock659
Old Sep 13, 2007 | 07:13 AM
hic316's Avatar
I have a similiar cracking noise, it is only when i go over small abrupt bumps, but I can't make out if it is coming from the front or back.
Old Sep 13, 2007 | 11:24 AM
Busboy's Avatar
Loose shocks? Mine came from the factory that way.
jetsnow
Sep 10, 2006 12:09 PM
Gordonville
Apr 18, 2005 09:45 AM
00turbo
Sep 19, 2004 08:32 PM
abb
Sep 23, 2003 10:46 AM
Mr. 45
14
Apr 25, 2003 06:22 PM
