Front Axle Question
Old Jan 29, 2007 | 05:08 AM
SMOKNISB's Avatar
Front Axle Question
I replaced my CAD Vacuum motor last week. The one that was in it had a bent shaft. I also replaced the worn out shift fork. The was hardly anything left of the fork. My question is, is there a spacer that holds the passenger outer axle centered in the axle tube? It moves around quite a bit right now. It looks like the passenger inner axle has some sort of spacer to hold it centered. If there is one, can it be replaced without removing the axle?
Thanks
Old Jan 29, 2007 | 08:59 AM
nitrousn's Avatar
There is a intermediate shaft support bearing and a combination pilot bearing/spacer where the two shafts but togeather. I suspect that is whay you wore the fork and twisted the shaft. Look here.
http://www.quad4x4.com/Dodge%20Frt%2...xle_Shift_Kits
Old Jan 29, 2007 | 09:05 AM
SMOKNISB's Avatar
So I guess I need the Right Axle Bushing and Bearing Set. Anyone know if you have to take the axle out to replace these.
Old Jan 29, 2007 | 12:14 PM
nitrousn's Avatar
Of course you have to remove the axle.
Old Jan 30, 2007 | 01:35 AM
SMOKNISB's Avatar
yeah I was hoping I didn't have to pull the axle. I just had the front hubs off 2 weeks ago and that would have been the time to do it. I really don't feel like doing it again.
csramsey640
Jun 4, 2014 10:31 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
Hawkeye
Apr 29, 2008 10:24 AM
Commatoze
Oct 1, 2003 01:07 PM
