FP gauge install question
Old Jan 15, 2005 | 04:46 PM
Firewawk's Avatar
There are 2 plugs on the top of the fuel filter housing, can these be used to intall my fuel pressure gauge? If I can use them for fuel pressure readings which one of them do I want to use to get post filter readings?
Old Jan 15, 2005 | 05:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
This is my '99 setup to monitor Post fuel filter pressure readings.
https://www.dieseltruckresource.com/...ure_Hookup.jpg
Old Jan 15, 2005 | 05:22 PM
Geico266's Avatar
You got it! Use the set up Shovel has there are you are good to go! The needle valve is optional, but a really good idea if you have a leak!
Shovelhead, a clean engine = sick mind!
Old Jan 15, 2005 | 05:42 PM
Firewawk's Avatar
Thats it!! With the install being that easy what are people always messing around with tapped banjo fittings and schrader valves?
Thanks
Old Jan 15, 2005 | 06:05 PM
Shovelhead's Avatar
The 98.5s and the '99s are the only ones that used this filter canister design.
In 2000, Dodge changed it to a 'drop-in' type setup to make it easier to change the filter.
Old Jan 15, 2005 | 08:26 PM
RATTLINRAM's Avatar
Wish mine was that clean,,,,,,,
Old Jan 15, 2005 | 08:34 PM
Geico266's Avatar
Better get the Simple Green out and give her a bath! I'm not sure what a dirt engine means!
ado2b1
Jul 6, 2007 10:27 PM
chrismez
Sep 3, 2003 08:23 PM
jbs007
Jul 24, 2003 12:58 AM
apc
Apr 8, 2003 05:51 PM
White02Sport
Oct 6, 2002 07:11 PM
