FP gauge install question
There are 2 plugs on the top of the fuel filter housing, can these be used to intall my fuel pressure gauge? If I can use them for fuel pressure readings which one of them do I want to use to get post filter readings?
This is my '99 setup to monitor Post fuel filter pressure readings.
https://www.dieseltruckresource.com/...ure_Hookup.jpg |
You got it! Use the set up Shovel has there are you are good to go! The needle valve is optional, but a really good idea if you have a leak!
Shovelhead, a clean engine = sick mind! [laugh] [eyecrazy] :o |
Thats it!! With the install being that easy what are people always messing around with tapped banjo fittings and schrader valves?
Thanks |
The 98.5s and the '99s are the only ones that used this filter canister design.
In 2000, Dodge changed it to a 'drop-in' type setup to make it easier to change the filter. |
Originally posted by RATTLINRAM Wish mine was that clean,,,,,,, :rolleyes: https://www.dieseltruckresource.com/...0_0022-med.JPG |
