finding drain back
Old Jul 17, 2008 | 01:03 PM
musthave's Avatar
finding drain back
1999 2500 ram Need to change converter drain back valve. Dealer can't find part
number and location. I know it is located in the pressure line(outlet) near radiator tank. Need help with part number and exact location. (47RE)
Old Jul 17, 2008 | 10:36 PM
badme's Avatar
open hood find rubber hose by radiator follow until it turns to steel valve is there. Call 1-800-newcar1 ask for parts and tell them what you want. They are great and should know the part # with out even looking.
Old Jul 17, 2008 | 10:50 PM
biododge1's Avatar
it is located in the trans cooler outlet presure line-it(drain valve) has a barbed fiting on one end and a flare on the other. an arrow shows flow direction.
thats the book instructions, however i went out to find it my self-nada. i searched every inch of line and nothing. every thing is stock related to trans so if its there, it is not the same as book describes.... how bad is your valve loosing psi? if it takes a few days i belive thats the norm iirc (mine drains back after about 3-5 days).
Old Jul 18, 2008 | 12:33 AM
67HotRod's Avatar
Mine was at the heat exchanger in the inlet side, its gone now.
Old Jul 18, 2008 | 10:47 AM
musthave's Avatar
It takes about 2 days to drain. Which trans cooler anti freeze or air. Will try calling the 1-800 number next.
Old Jul 18, 2008 | 09:16 PM
Shameless's Avatar
I believe the part you are looking for is in the cooler at the front of your truck. As fluid enters the cooler it is either alowwed through the cooler because the valve is open of is diverted through a single tube and not allowed through the entire cooling circuit of the cooler. The reason they were unable to to find the part you are looking for is because it is an integral part of another and can not be purchased seperatly.
Old Jul 18, 2008 | 09:39 PM
scottsjeeprolet's Avatar
It's on the heat exchanger on the pass side of the block behind the turbo the left fitting is the one with the check valve. I took mine out and just used a 1/2"npt x 1/2" tube stainless compression fitting.
Old Jul 21, 2008 | 10:11 PM
musthave's Avatar
Called the 1-800 number. The person said he would look for the part and call me back but he never did. Thanks for all replies and info.
Oldsmobiler
Feb 6, 2010 03:40 PM
klx650a2
Jan 10, 2008 12:08 AM
JoshPeters
Apr 3, 2005 08:13 AM
TurboTed
Feb 11, 2004 05:47 PM
wooff
May 1, 2003 11:22 AM
