Fan Belt
Old Dec 31, 2004 | 01:19 PM
bishgeo's Avatar
Question Fan Belt
Any tips or tricks other than just pulling the idler out of the way.Thanks
Old Dec 31, 2004 | 05:06 PM
rockwithjason's Avatar
There is no special trick to it. You just insert a breaker bar in the idler and pull it back. After that you can pop the belt off and thread the new one.
Old Dec 31, 2004 | 06:05 PM
bishgeo's Avatar
Thank's.It is always better to ask befor you do somethin stupid and have to explain to your wife why you nedd to spend another 100 to fix what you broke.!!!
Old Dec 31, 2004 | 09:39 PM
fschiola's Avatar
Yes, being proactive is usually best.
Old Dec 31, 2004 | 10:36 PM
amartinson's Avatar
After you remove the belt, check the idler itself for any play or grinding in the bearing. A bad idler will tear up a new belt and leave you stranded.
Old Jan 1, 2005 | 01:20 PM
Sidewinder's Avatar
When the belt is off I usually give all of the pulleys a quick hit with a wire brush to clean out any debris then spray them with brake cleaner before installing the new belt. Just to make sure everything is clean.
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
big jimmy
Jul 7, 2006 01:33 PM
apwatson50
Mar 3, 2006 06:26 PM
dodgeman01
Dec 20, 2002 09:45 PM
