Error codes causing LP not to work...
Could someone tell me why it is that when a MAP sensor triggers the check engine light that the LP stops coming on for 3 sec before you start the truck? Why would a MAP sensor code have anything to do with this?
Secondly what symptoms do you have if the bypass valve on the VP44 isn't working properly?
My truck is 02, but I with you 100%. The MAP code and LP run don't seem related. I am only guessing that you have separate problems. I have thrown a few MAP codes myself.
This is how the LP works on my truck. Turn the key to ON and LP runs for about 1 second. Turn the key to START and the LP runs continuesly while key is ON or for about 30 seconds if the key is turned to OFF.
Jim
Jim
67HotRod
03-04-2005 07:47 AM
