DMF causing codes?
Old Aug 13, 2010 | 06:43 PM
2002Dodge's Avatar
DMF causing codes?
I'm thinking so. The DMF is about to take a leave of absence on it's own. This week it finally got to shaking bad enough to order a dual disc from South Bend. Sometimes right after starting while still at idle it throws P0302 and P0341 and sometimes the code for #5 miss fire. On the way home today can't go over 56 mph or about 1800 rpm. Looked in the gap at the bell housing and see a spring the size of a small block Ford valve spring and two tapered roller bearings.
This is on my 2006.
Old Aug 14, 2010 | 10:00 AM
TedT's Avatar
I used to work on Porsches and can tell you that on a 996 a bad dmf can cause a misfire code.
Ted
Oliverpuller
May 8, 2011 07:24 AM
Roperteacher
Jul 15, 2010 11:26 PM
ratlratl
Feb 2, 2008 12:04 AM
ratlratl
Dec 30, 2007 06:24 PM
kuhkuhkyle
Jul 30, 2007 07:01 PM
