Removing DMF question
Old Jan 31, 2008 | 07:26 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Question Removing DMF question
PREFACE: To all non-newbies here, if you find a thread on this, please post a link. I could not.
I'm planning my clutch replacement job soon and need an easy answer from someone who has done their's before. Does the Dual Mass Flywheel, after the clutch and plate are removed, simply unbolt from the crank and come out as one piece? Or is it actually two pieces, one being the flywheel and the other being like a flexplate that i'll have to borrow a barring tool to do? Truck is in sig.
TIA
Chris
Old Jan 31, 2008 | 07:32 PM
Spooler's Avatar
From reading on here it is 2 pieces. Flywheel surface bolted to the flexplate. The bolts for the flywheel surface are on the back side of the flexplate just like if you were doing a auto tranny removal of the TC. You will need a barring tool to spin the motor.
Old Feb 2, 2008 | 12:04 AM
06trx's Avatar
On the pass. side there is a plate that you need to take off. In there is where you can get to those bolts. You can turn the fly wheel with a bar. BE VERY CAREFUL, THAT THING IS HEAVY when you get the last bolt out.
Oliverpuller
May 8, 2011 07:24 AM
2002Dodge
Aug 14, 2010 10:00 AM
Roperteacher
Jul 15, 2010 11:26 PM
ratlratl
Dec 30, 2007 06:24 PM
kuhkuhkyle
Jul 30, 2007 07:01 PM
