Engine Warning Light
Any idea how to get rid of the engine warning light.
I can't get it to go out. I do have 1 p-code 1693.
The truck runs fantastic, Good FP, Good power.
no problems except the warning light.
________________________________
You will have to have a scan tool to do it, I believe. I've had that error and the only way I got rid of it was with a scan tool. Disconnecting the batteries didn't work. Your Edge may have set the error, so don't be surprised if it comes back.
Ok,
I went to Autozone and had the guy check the codes. The code I couldn't see was a P-0237 Map sensor voltage to low. Had a bad connection. Reseated the connector, cleared the code the truck is happy now.
Joey-D
Dec 12, 2011 12:52 PM
huron52
Oct 24, 2009 09:27 PM
Batts
14
May 5, 2006 03:35 PM
