Engine swap
Old Aug 12, 2019 | 08:00 PM
Kbtaz's Avatar
Engine swap
I have a 2002 Cummins in a wrecked truck and I want to put it in my 2005 truck with a blown Cummins. What do I need to know to make this happen.
Thanks in advance
Old Aug 14, 2019 | 01:44 PM
KATOOM's Avatar
You'll basically need everything in the '02 which has anything to do with engine control management and fit it in the '05. You may even run into issue with the dash cluster since nothing will connect correctly to the '02 OBD system. Not saying its not possible but that its going to be an effort.
Old Aug 14, 2019 | 02:44 PM
SIXSLUG's Avatar
Sounds like a can of worms, sell both and start over with a solid used 03-05...
Old Aug 14, 2019 | 03:03 PM
Even if you got it running right, it would never pass any inspection that involves testing the exhaust PPM.
Getting a '02 VP-44 motor to run as cleanly as a common rail truck would be the real trick.
Old Aug 16, 2019 | 10:44 PM
Kbtaz's Avatar
Could we use just the motor and use all the 05 peripherals?
Old Aug 16, 2019 | 10:49 PM
KATOOM's Avatar
I dont have the answer to that as you never hear of anyone swapping a 2ng gen motor into a 3rd gen truck. Depending on how badly damaged the '05 motor is, it would likely be a lot easier just to rebuild or fix that engine.
Old Aug 17, 2019 | 10:32 AM
If you are asking can you just stick in the complete VP-44 24V motor and plug it into the '05 wiring, computer, throttle cable ETC and such.
I would bet a wad of cash the answer is no.
Old Aug 19, 2019 | 09:46 AM
AggieJustin's Avatar
I would think the only thing you could re-use would be the block. Then entire top side of the engine would have to come from the '05 with the electronic injectors and the fuel rail. If you tried to re-use any of the VP44 fuel system, then you would need all the '02 engine control pieces and that's where it gets hairy tying back into the '05 dash systems.
kellen23
Cummins Conversions
Feb 5, 2008 06:45 AM
SILVERSLEEPER
May 4, 2007 05:39 AM
rolling18
Oct 30, 2006 10:31 PM
enormus
Jul 4, 2006 09:14 AM
White02Sport
Nov 12, 2004 02:41 PM
