Engine squealing
Possible causes in order of possibility;
Loose or bad belt. If loose, check the auto tensioner.
Bad alternator bearings.
Water pump.
Fan. (remote possibility)
Let us know the cause after you find and fix it.
Water pump.
Turbo boot either developed a small hole, or is starting to work lose.
Your "squeal" is pressurized air leaving the intake system quickly.
Check all rubber boots connecting the turbo to connector, connector to intercooler, intercooler to connector, connector to intake.
Check both visually and "manually" meaning rub your hands all around checking for tears.
Check all clamps connecting said boots to said intercooler parts.
Just an educated guess.
For future posts, it would help immensely if you had a signature filled in, year make and model of truck, 12 or 24 valve, any modifications, etc.
"user cp" button up thar, then "edit profile", fill in box labeled "signature" see below this post for a mighty fine example of a really big signature.
phox
phox
I checked my turbo boot and my turbo, both my turbo has no up and down side to side or stops in it and my boot was fine i tightend it and it stoped making the a squeal now its making more of a chirp that i can hear just idleing.
See above gleaned from my first post in the thread.
2 on each side, with a hard connector between them.
phox
