E-brake adj, 4wheel disc
Old Jul 15, 2007 | 05:09 PM
SIXSLUG's Avatar
Can anyone tell me off the top of their head which way to turn the adjuster wheels for the emergency brakes on an 01.5 w/ 4 wheel discs. My adjustment for the cable has reached the end and it still won't hold the truck on a slight incline.
Old Jul 17, 2007 | 09:18 PM
SIXSLUG's Avatar
I'll answer this one myself......adjust the star wheel DOWN to adjust the e-brake pads on a 4wheel disc truck. Live-n-learn. KM
Old Jul 22, 2007 | 08:14 PM
SIXSLUG's Avatar
Ok I'm back on this topic. Adjust drivers side star wheel "up" to tighten and passenger side "down" to tighten the e-brake drum shoes for 4 wheel disc brakes. I actually bottomed out the drivers side by going down and had only the passenger side rear wheel holding the truck when emergency brake was applied.
Old Jul 22, 2007 | 08:16 PM
Homestead's Avatar
I've always found it easier to just pull the wheels. Gives you chance to check things over. Last time I did it, I found I had a leaking hub seal, but you couldn't see it with a visual inspection from the outside.
It wasn't much of a leak but enough to take the brakes out on that side.
Jeff
Old Jul 26, 2007 | 04:53 PM
SIXSLUG's Avatar
Yeah, I ended up disassembling both sides and cleaning out the drums for the e-brakes and lubing the adjusters. THere was a lot of dust and crud in there..but no leaks. Thanks, Kurt
pullin hard
Mar 5, 2009 08:06 PM
n2moto
16
Jan 22, 2009 10:25 PM
scuzman00
Mar 13, 2006 01:58 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
