Dually advantages?
Dually advantages?
So, in doing some research here in this forum, I have learned that there is only 2" overall difference (1" per side) between a drw dana 80 and a srw dana 80. I am considering a dually conversion, and my question is, regarding the rear end, are there any benefits to actually converting to a factory dual rear end? Or is it just easier to get some 1" spacers on the rear with longer lug studs? Is there any strength difference between the dually dana 80 vs the single?
dually conversion
I'm going to convert my 99 2500 to a dually, haven't started yet just doing research now. Found a website southwestwheel.com that has dually conversion kits. Anyone have any experience with this? Also at chromewheel.com
If you use a dually for hauling or heavy towing, there is nothing better. If bopping around town and trying to park they are a PIA esdpecially a manual eqauiped one. Would not have as only vehicle. JMHO of course.
You might want to double check your numbers. The pickup DRW D80 is wider than the Cab and chassis DRW D80, which is again wider than the pickup SRW D80. Dually wheels will not fit on to a SRW drum brake rear end, and I don't think 1" spacers will make up that difference. If I recall my measurements, the pickup DRW D80 was about 79" WMS to WMS. Meausre your SRW and see.
That was my point, as the OP said he found out the SRW was only 2" narrower than a DRW, I was saying it was more than that.
the496rocket
Jun 25, 2007 03:59 PM
jrussell
19
Jun 4, 2007 08:36 PM
dieselnewbie
57
May 10, 2004 02:41 PM
dieselnewbie
47
Apr 14, 2004 06:17 PM
Timinva
Apr 26, 2003 04:54 PM
