dropping a couple cylinders and blue smoke
Hi Everyone,
My truck is exhibiting a curious berhavior. Sometimes my truck will accellerate slowly/low power, even at WOT. It seems to lug or miss as if it had dropped a cylinder or two.
It happens intermittently, and usually after a short stop.
It is not predictable, and I can not make it do this on demand.
It goes away if I release the accelerator and press it again.
It will blow blue exhaust if I leave the accelerator pressed while it is acting up.
No boxes or mods. No other known defects. 98.5 / 24v / auto.
Any ideas out there?
Zip up to the tech facts section and look up the relearn procedure for APPS. Do that and see if the problem goes away.
If the problem continues and your delivery fuel pressure is good, then I would suspect the VP44 is losing the housing around the delivery valve and bypassing fuel pressure when the housing gets stuck. When that happens it it time to get a rebuilt VP44.
Pressure is not always an indication of proper flow.
Originally Posted by abbeyinc
My fuel pressure is okay. 11 at idle, 6 at WOT. It is consistent.
The pressure is measured on the outlet side of the filter.
Johnsoncattle
10-10-2011 07:44 PM
Turbo Deeezle
177
07-06-2009 07:39 PM
bensdad_canada
05-09-2005 10:56 PM
big red psd cc
14
09-01-2004 01:39 PM
