Death Wobble
Old Mar 5, 2008 | 07:51 AM
scroshba06's Avatar
Death Wobble
OK, I HAVE READ SOME ABOUT THIS AND REALLY NEVER PAID ATTENTION TO IT........... BUT TODAY AT 70 MPH IT HAPPENED TO ME.......... WOW I THOUGHT I WAS DEAD... ANY ONE HAVE ANY IDEAS AS WHAT IT COULD BE ???????????
Old Mar 5, 2008 | 08:25 AM
nickg's Avatar
Loose wheel nuts
loose or failing front end parts
bad U-jointBad hanger bearing
Broken belts in a tire
bad wheel bearing
Bad power steering box
bad shocks
And the list grows.....
Dont drive the truck until you check it over!
Old Mar 5, 2008 | 10:16 AM
CTD NUT's Avatar
Good old DW is caused by worn front end parts and some times in conjunction with poor alignment.
The usual suspects are:
Worn track bar joint at the frame
Worn tie rod ends
Loose/worn pitman shaft bushings in the steering box (remedied with a DSS)
Worn out steering damper
Not enough positive caster - These trucks need at least 3.5* of positive caster. Do not listen to alignment people who say it is "in spec". The range of "in spec" is far too broad to be useful on these trucks. When at an alignment shop, insist on the 3.5* minimum caster spec. If they won't do it, go to a shop that will.
Also, keep in mind that DW can be caused by a combination of these problems so, check everything.
Old Mar 5, 2008 | 09:17 PM
dozer12216's Avatar
70 MPH issue perhaps has more to do with tires/wheels. Is mud stuck inside a wheel? It was a brake caliper on mine. Replace in pair.
Did body shake up and down or did steering wheel oscillate.
Old Mar 6, 2008 | 06:51 AM
scroshba06's Avatar
oscillate BAD
Old Mar 6, 2008 | 07:08 AM
Fishin2Deep4U's Avatar
Check every part of the front end today!
Usually a worn track bar sets it off. Leveling kit by chance?
You may want to crank the caster back on the adjusters too. That will help.
Dave
Old Mar 6, 2008 | 09:09 AM
scroshba06's Avatar
Thanks Everone
Old Apr 2, 2008 | 10:03 AM
scroshba06's Avatar
Here We Go Again..... New Track Bar.... For A Week Things Were Good Untill Yesterday..... Thw Uncrolled Shaking Happened Again..... Anyone Got Any Ideas Now
Old Apr 2, 2008 | 02:37 PM
nv_brewer's Avatar
I replace my TB and didn't completely cure DW until I replaced the shocks. Haven't experianced it in over a year.
Old Apr 3, 2008 | 10:24 AM
oldschoolrides's Avatar
Is yours this bad?
http://youtube.com/watch?v=wj9PNNChVm4
Old Apr 3, 2008 | 05:58 PM
scroshba06's Avatar
oldschool.............. not that bad...........wow
Old Apr 3, 2008 | 08:46 PM
Lol, I'd hope not! But like everyone else said check all the joints an the track bar.
725Gus
Mar 6, 2014 09:49 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
smokindodge1996
Feb 13, 2004 08:54 PM
moneypit
Sep 23, 2003 06:06 PM
