dead pedal
Old Jan 19, 2009 | 04:32 PM
fisherjaw's Avatar
dead pedal
over the last couple of weeks my 99 dodge 2500 will only give me half trottle responce, for a few minutes, then will clear out and run fine for awile. i recently put a new vp44 and holly blue fuel pump in it. i am not getting any codes. i am out of ideas any help would be appreciated. thanx
Old Jan 19, 2009 | 08:10 PM
dozer12216's Avatar
Could you have a restricted fuel filter?
Have you checked LP pressure at the IP??
Is it possible you have a small air leak into fuel circuit???
Have you tried a APPS reset????
Clean all electrical connections?????
Old Jan 19, 2009 | 08:13 PM
Dinner's Avatar
Adding to Dozer's clean all electrical connections...might be worth something to take out, clean and test IAT and MAP sensors. Also check their plug connections for corrosion.
Old Jan 20, 2009 | 10:15 PM
fisherjaw's Avatar
what and where can i pick up a new iat, map sensor. where are they located i also just put a new fuel filter in and could find no leaks any where. thanks again
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
BillH
Apr 26, 2004 10:09 PM
mymaur
Jan 26, 2004 11:31 AM
