cummins reponse to power problems
Old Mar 2, 2004 | 04:23 PM
AlpineRAM's Avatar
Most spoilers we use look roughly like in that sketch
Usually the spoiler height can be adjusted to the load you pull.
Just my 2c
AlpineRAM
Old Mar 2, 2004 | 07:12 PM
farmer dave's Avatar
I don't know if one is really better then the other. I do know that the edge is cheaper. Is the blue chip a fueling box? that is another thing. I know when the time comes I am going to get a edge comp.
dave
Old Mar 3, 2004 | 07:19 AM
herb's Avatar
i was pretty much sold on the edge until the mecahic at cummins said the blue chip was better. if he had been trying to sell me one i could have shuged it off but he wasn't.
wish i was more knowledgable about what they do and why one would be better than the other
Old Mar 3, 2004 | 10:42 PM
Can you talk to the machanic some more, maybe he could tell you what the really advantage of the bluechip would be. I'd be interseted to know what he says, also ask if he has used it our is this just what cummins recommends. Maybe the are working together to make money, or maybe this is the only one that cummins had approved.
dave
Old Mar 4, 2004 | 07:18 PM
Haulin_in_Dixie's Avatar
I read the installation instructions on the Blue Chip box, it pierces the pump wire like a comp box. For long towing all the time I am afraid to do that. That being said, I like my EZ. Also they are giving you good information on the wind breaker. It is adding to your pulling problems. You would do better with a unit on the truck roof or none at all. Probably you are using it to protect the carrage on top, try a tarp instead. I do know that if you put EZ and injectors in it, you will be more than satisfied even with the air foil on top. I tow heavier, higher, and longer, with satisfaction.
Old Mar 4, 2004 | 09:26 PM
herb's Avatar
is there a signicant difference between the 2001 DODGE 24V EDGE "EZ " and the 24V EDGE "EZ COMP" ?
got to do something with this thing that works soon or am going to jump ship
Old Mar 5, 2004 | 09:55 AM
The ez is just a timing box that gives you about 60 hp, while the comp is adjustable a has different setting from stock to 120 hp and the comp pierces the wire.
dave
Old Mar 5, 2004 | 12:34 PM
herb's Avatar
thanks cummins shows a fault code 368 , bad vp 44---chrysler dealer not getting any fault codes without witch they cannot get ok for pump change.
Old Mar 5, 2004 | 12:50 PM
Cummins should be able to change the pump for you because it is a cummins. Is it still under warranty? If not do it yourself, get the pump from cummins. Atleast you finally have found out what the problem is. Good luck,
dave
Old Mar 5, 2004 | 02:29 PM
Mechanos's Avatar
How come Cummins can pull the code but Dodge can't... maybe Dodge "can't" because they didn't try because they don't want to buy a VP-44. Seems to me like you could get an official diagnosis from the Cummins dealer to take to the Dodge dealer and get it fixed. It's pretty sad that Dodge needs a "note from mommy" to give them permission to replace a part that they issued a warranty on.
Old Mar 8, 2004 | 05:43 AM
herb's Avatar
THEY PULL THEIR CODES OFF A DIFFERENT SOURCE THAN DODGE DOES.
Old Mar 8, 2004 | 02:08 PM
herb's Avatar
well i am back at point a again. chrysler dealer says they are not getting a code saying the v-44 is bad so they will not replace it.
cummins says it is bad but they cannot do chryslers warrenty work.
witch glass is the pod under?
Old Mar 8, 2004 | 02:18 PM
Mechanos's Avatar
Can you get the Dodge dealer to TALK to the Cummins dealer? If they talk to Cummins, you might get them to listen and agree that the VP-44 is bad. You might also see if you can get a signed affidavit from the Cummins dealer stating that the injection pump is bad and use that in court to get reimbursed for the new VP-44 you'll have to buy in the mean time.
Old Mar 8, 2004 | 02:31 PM
herb's Avatar
i am at the point of having way to much time invested into getting them to do what it needs to make it right. I really had hoped to be able to settle this amicabaly but starting to look like i am just going to have to turn it over to my attorney. He is on retainer so it won"t cost me anything initally to have him shake the bush's a little.
Old Mar 8, 2004 | 04:27 PM
amartinson's Avatar
Sounds like a good plan. You have certainly been patient enough.
