crankcase vent bottle
Old Apr 19, 2003 | 07:42 PM
bolo2's Avatar
Will it hurt to take the crankcase vent bottle off, or to not ever empty it. If I do take it off, is it going to leak oil all over my driveway?
Old Apr 19, 2003 | 08:19 PM
Idaho CTD's Avatar
Re:crankcase vent bottle
The best thing to do is to get 4' of 5/8" heater hose (take your existing hose with you cuz it might be 3/4&quot, a splice, and two hose clamps. Use the splice to hook to the existing hose and route it down below the motor but over the crossmember. Then you can zip tie the hose to the control arm bracket. No more dumping or mess on the front of your motor.
Old Apr 19, 2003 | 08:20 PM
mic646's Avatar
If you leave the bottle off eventually the underside of your truck will be covered in goo.
Old Apr 20, 2003 | 01:02 AM
KATOOM's Avatar
Yes it is 3/4 in. I got some hose, a barbed connector, and a 90* barbed elbow. Ran the hose under the engine in the frame to the crossmember and exited straight down with elbow. No leaks in garage. Just be sure to not let the hose sag or oil will collect and stop venting!
Old Apr 21, 2003 | 05:18 PM
Pit Bull's Avatar
Just empty it every other oil and filter change.
Old Apr 23, 2003 | 11:18 AM
latitud_rt's Avatar
An old sock... What a great idea, now if I can just find one..,maybe I will search the dryer. Oh, look! jackpot I seem to have several (dozen) singles in my sock drawer. The wife must have already had the idea to use a sock and forgot to tell me about it.<br><br>Tim
Old Apr 23, 2003 | 12:54 PM
Diesel fitter's Avatar
&quot;The best thing to do is to get 4' of 5/8&quot; heater hose (take your existing hose with you cuz it might be 3/4&quot, a splice, and two hose clamps. Use the splice to hook to the existing hose and route it down below the motor but over the crossmember. Then you can zip tie the hose to the control arm bracket. No more dumping or mess on the front of your motor. &quot;<br><br>There is a TSB #09-009-02 concerning this issue I had the modification done on my truck and have been extremely pleasded with the result. The procedure eliminate4s the breather from the timing chain cover and moves it to the tappet cover on the side of the engine block where it belongs and routs the hose down behind the starter. Since the modification which I had done 3k ago not a drop of oil anywhere on the engine
Old Apr 23, 2003 | 02:14 PM
Pit Bull's Avatar
[quote author=Diesel fitter link=board=4;threadid=13799;start=0#131007 date=1051120452]<br><br><br>There is a TSB #09-009-02 concerning this issue I had the modification done on my truck and have been extremely pleasded with the result. The procedure eliminate4s the breather from the timing chain cover and moves it to the tappet cover on the side of the engine block where it belongs and routs the hose down behind the starter. Since the modification which I had done 3k ago not a drop of oil anywhere on the engine <br>[/quote]<br><br>What did that cost you?
Old Apr 23, 2003 | 03:32 PM
BigBlue's Avatar
SInce I'm under warranty, I shouldn't have to pay for that. Right?
Old Apr 24, 2003 | 10:58 AM
silver_goat's Avatar
How hard is it to relocate the bottle. Everytime I change my oil I get under my truck and clean all that mess up. Sure would be nice to not have all that mess on the front of my cummins.
pugdog
Aug 6, 2012 10:22 PM
Straight6
Aug 22, 2008 11:20 PM
Wes in TN
Oct 17, 2005 08:49 AM
Ruadh
Jul 6, 2003 01:48 PM
camomullet
Mar 26, 2003 11:42 PM
