Cpk Problems
Old Mar 26, 2008 | 11:53 AM
OGDAWG0680's Avatar
Exclamation Cpk Problems
Well my CPK is obviously out i lose my tach and extra power when running down the highway. I got all the infomation on how to fix it. u know the usual remove starter and what not but did all that and there is no CPK there!!! So i went and called the local dodge dealership and they tol me on my truck 2001 2500 2WD the CPK is behind the ECM but ive never heard of this. Just wondering if there is any other sensor/switch/wire that could be loose or that i need to check.....
Old Mar 26, 2008 | 06:38 PM
Fishin2Deep4U's Avatar
No CPK on the '01 that I am aware of.
You have a cam position sensor behind the VP44. If you lose the tach at low speed, it's the speed sensor in the trans usually. If at high speed, look at the unit on top of the rear differential.
What codes are you getting??
Dave
Old Mar 26, 2008 | 06:44 PM
98.5Hotrod's Avatar
I think you will have to replace the cam sensor.
Old Mar 26, 2008 | 07:24 PM
jakeydiesel's Avatar
cam sensor can be get at with a couple extensions, below the vp, but above the ps steering pump...a 5mm hex head will pull it out...jake
Old Mar 27, 2008 | 02:13 AM
I would get those codes first. It could be completely unrelated to the CPS.
Dave
Old Mar 27, 2008 | 09:04 AM
OGDAWG0680's Avatar
Im Getting A P1693 Code
Old Mar 27, 2008 | 03:59 PM
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
This only tells you a code has been set, but not the code. Check it again.
Dave
DJ Turbo.
Oct 13, 2011 09:11 PM
OGDAWG0680
Mar 26, 2008 09:04 PM
95 Dodge
Jul 2, 2006 03:28 PM
BigBlackDodge
Jan 8, 2003 05:57 AM
TJinTX
Jan 7, 2003 08:19 AM
