correct way to change a fuel filter.
Old Mar 18, 2009 | 12:26 PM
nasty01cummims's Avatar
i usually have them change when i change the oil but shes kinda runnin ruff so im gonna change the fuel filter and hope that fixes the problem. I just need to kno how.
Old Mar 18, 2009 | 02:09 PM
stevenl's Avatar
just thake a wrench and take the cap off the fliter housing and remove the old one and drop in the new one, )make sure it goes in the right way. correct side up) and then screw the cap back on, not to tight as to make sure to not crack it. then bump the starter a time or two to fill the canister back up and you will most likely have to bleed the system. so just crack the number one fule line while you have someone crank it and once it starts and fuel comes out of the line you cracked snug the line back down and you are all done.
Old Mar 18, 2009 | 03:47 PM
RAM2940's Avatar
Just remove old filter, wipe out bowl, refill bowl about halfway with fuel, reinstall filter and screw on lid, bump starter to run lift pump for 25 sec. do this 2 times, start truck.
Onemoparnut
Jul 21, 2013 08:17 AM
BC-01-CTD
Jan 25, 2010 08:01 PM
mstep3
Jul 14, 2009 07:52 AM
steelblitzkrieg
Feb 9, 2007 04:35 PM
jlipskoc
Nov 27, 2006 09:27 AM
