coolant question?
Old Oct 23, 2011 | 12:04 PM
blackenedman's Avatar
coolant question?
I need to replace my block heater. The coolant in the truck currently is of unknown brand/type. I didnt really want to totally drain/refill, just drain enough to replace block heater.
After reading, I'm afraid of adding coolant to the system that may be incompatible with what is in it currently. Thoughts or comments on this? Ive read where the coolant should be of a HOAT type (zerex, etc) but without knowing whats in the truck, I'm unsure it has a HOAT type or not?
As always, thanks for any insight...
Old Oct 23, 2011 | 02:12 PM
torquefan's Avatar
The coolant on a 2000 truck is supposed to be the standard green stuff. They never came with extended life coolant until the common rail engines in 2003. If it was me, I'd consider this a great time to change the coolant if I had to drain at least half of it to replace a part.
And if you're not sure what's in it, give it a good water flush after you drain it. Also I've never seen any compelling reason to 'upgrade' a vehicle to extended life coolant if it came with standard coolant originally.
Old Oct 23, 2011 | 08:52 PM
SIXSLUG's Avatar
If you are in a pinch top it up with distilled water, or drain the existing coolant off into a clean bottle and re-use it..
If you top it off with distilled water check it for freezing level before trusting it this winter.
Old Nov 1, 2011 | 12:18 PM
Thanks for the replies. I guess I read too much into the hoat type huh? I didnt really find anything definitive in the manual, one way or the other, as far as which coolant to use.
The coolant in it currently is best described as "brown", so I'd say its definitely time to replace. Will most likely drain, flush, replace with regular old green coolant.
Seeing other comments about fragile drain petcocks, I will probably just drain from the lower hose.
Any thoughts on the petcock? If it's like any other piece of plastic on the truck, it will break as soon as I look at it!
Old Nov 1, 2011 | 03:54 PM
SIXSLUG's Avatar
The petcock turns about 1/4 then you pull it straight out.
Most overturn it and break it.
Make sure you use ethylene glycol coolant. Its called out in the Cummins specs.
Old Nov 2, 2011 | 12:31 AM
phal's Avatar
oops
oopsie, double post.sorry
Old Nov 2, 2011 | 12:32 AM
phal's Avatar
petcock
What sixslug said...
I was stressed about the petcock also but no problem once I figured out how it worked. Just dont go all neanderthal on it.
Old Nov 2, 2011 | 04:05 PM
SIXSLUG's Avatar
That's some golden advice right there!!
Old Nov 6, 2011 | 01:37 AM
Dane's Avatar
My 2001 HO came with G05.
Amazon has it with free shipping -
http://www.amazon.com/Zerex-ZXGO51-G.../dp/B0033QNZZ0
Old Nov 6, 2011 | 02:53 AM
New2Diesel's Avatar
"Gomer Pyle"
Go to Geno's website. He has an amazing read on coolant selection from the Turbo Diesel Register. It is well worth the understanding.
Old Nov 6, 2011 | 08:02 AM
Copenhagenjunkie's Avatar
Another good thing to do is remove heater hoses and flush the heater core independent of the entire system.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
Jim5870
Feb 2, 2006 12:59 AM
popeyesides
Dec 6, 2004 03:43 PM
