converter not wanting to unlock
Old Mar 29, 2010 | 01:30 AM
turbodiesel101's Avatar
ok i was on the last section of my drive tonight and just after dodging about 20 deer in the road and a downed tree out of the blue my trans started to act up. it had been unlocking and locking a lot more than normal on the drive but now it does not want to unlock at all. to get stopped i have to manually shift down to second or first and it will jump a little and unlock but the second it goes back into D it locks right back up and wont unlock. no codes and im to tired to mess with anything now but any suggestions would be great. could this be bad grounds or issues more serious? trucks a 99 LWB with 176,xxx miles and mods are edge EZ, gauges, smoke switch, Goerend torque converter hd clutch packs and valve housings i think thats all that done right now. i do not have a lockup switch.
Old Mar 29, 2010 | 10:34 AM
mastertech's Avatar
sounds like a bad convertor if thats truely whats happening
Old Mar 29, 2010 | 12:51 PM
cleaned some grounds and terminals on the batts and no change...
Old Mar 29, 2010 | 02:20 PM
dozer12216's Avatar
Lockuup solenoid could be stuck open or valve could be stuck in vb. Possible grounded wire for lockup solenoid, but should generate a fault code.
Since it does unlock and seems to lock in drive, I suspect the converter is not the real problem. It is just responding to oil flow in valve body. JMHO
Old Mar 30, 2010 | 01:51 AM
hope its not the converter... its at the shop so we will see whats up soon i hope...
Old Mar 30, 2010 | 07:51 AM
nickg's Avatar
faulty brake switch?
Old Apr 10, 2010 | 11:45 PM
well its fixed so i thought i would post what the problem was. there was a broken spring in the valve housing... all this work for one little bitty broken spring haha
96WhiteBuffalo
Mar 30, 2010 07:38 AM
bose901
Dec 31, 2007 10:07 PM
rokspydr
Nov 8, 2007 12:50 PM
Voss
Jun 5, 2005 12:45 PM
DF5152
Dec 23, 2003 11:07 PM
