Comp Box on...Oh my!
I installed couple hrs ago.............
My gauges arent in yet so i just have on level 2......All i can say is if you havent already got one then u gotta get it.......
One question.....The tapped wire for the injection pump....I'm assuming i have it correct right.....Directions were kinda vauge, and the pic was no help......Would everything function properly if i grabbed the wrong wire?
Did you run it with out the pump wire?
If it runs better you got the right wire.
Now, get the fuel pressure guage in soon.you are capable of using more fuel and the pump will die without fuel to cool it. 10 psi minimum at loaded/max RPM.
I have had my comp box for over a year and still am tickeled to pieces with it. since I have had installed EDM injectors and a pe 4200 fuel pump replacing the stock lift pump. those mods are about 7 months old and still WOW.
I didnt run it without the wire but i could go and unplug and check the difference......I'ts gotta be correct because this baby is haulin......
Gonna rain tommorow so cant do gauges....
BBQ later so no time.....I cant imagine when my injectors go in.....And the DTT trans,,,,,,,,,
It really is unbeliveable the difference this makes....I could only imagine a bigger turbo etc......
If you have the wire tapped to the right one and turn it up you should see more smoke! Turn it to 5x5 and step on it if there is more smoke it should be right then turn the box back down so you don't burn it up. For what it is worth I did my pyro pre turbo.
bwarning01
15
08-24-2007 09:19 PM
04ctd
10-05-2006 08:27 PM
flinn101
14
12-14-2005 09:43 PM
hellotbone
07-12-2003 12:58 AM
