codes 0645, 1693
Old Oct 27, 2008 | 06:10 PM
southerman's Avatar
codes 0645, 1693
ok just replaced lift pump a couple of days ago,every morning since truck drags when you try to start it, once it starts the overdrive light come on. so i cycled my ingition, got codes,0645,1693. truck still has plenty of power what gives?
Old Oct 27, 2008 | 07:39 PM
slim51015's Avatar
0645 A/C Clutch Relay Circuit
1693 DTC Detected In Companion Module, DTC Detected In PCM/ECM
Old Oct 27, 2008 | 09:03 PM
southerman's Avatar
what is dtc is this aproblem or can u resett it?
Old Oct 27, 2008 | 09:57 PM
slim51015's Avatar
DTC Diagnostic Trouble Code
My guess, if you fix the 0645 the 1693 will disappear also.
Did you bump or pull any wires while replacing the lift pump?
ISBPWRdRam
Apr 20, 2006 04:12 PM
jwill72_03
Feb 16, 2005 08:55 PM
BillH
16
Sep 10, 2004 08:51 AM
D.T.O.
Jul 27, 2004 07:19 AM
scottrod
Nov 2, 2002 05:12 PM
