codes 0500 and 1693
Old Nov 1, 2002 | 07:35 PM
scottrod's Avatar
codes 0500 and 1693
I have my EZ sold so after I removed it and the turnbuckle, I started the truck and moved it over in the garage. Then I thought I would check for codes. Here is what I have:
PCU 0500
ECU 1693
Anyone know what they mean, or a web site that has a list of them?
Thanks guys, Scott
OH yeah- it's an 01, auto, 4x4 ;D
Old Nov 1, 2002 | 07:48 PM
admin's Avatar
Re:codes 0500 and 1693
Check the FAQ under ODBII and ODBIII<br><br>From what I gather, 0500 is Vehicle Speed Sensor Malfunction and 1693 is Turbo Charge Control Circuit Malfunction. Don't know if that's what they are for sure, so you should probably verify that by going to the dealer, or calling them.
Old Nov 1, 2002 | 08:24 PM
phox_mulder's Avatar
I thought 1693 was a generic &quot;other code stored in ECM&quot;<br><br>The PCM is a Dodge part, the ECM is a cummins part (or vice versa), the odometer only reads the codes in the Dodge part, not in the Cummins part.<br>(the reason Dodge can't dig deep enough to find all the codes created by the fueling boxes, but Cummins can)<br><br>I think,<br><br>phox<br><br>
Old Nov 1, 2002 | 08:48 PM
scottrod's Avatar
Thanks- Isn't there a website that lists all the codes??
Old Nov 1, 2002 | 09:44 PM
StakeMan's Avatar
Yep, 1693 is a generic code. I have been clearing it but it keeps coming back.
Old Nov 1, 2002 | 10:10 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
0500 (vehicle speed sensor fault) is a pretty standard one to see if you've had an EZ on a vehicle. Typically caused by some moisture getting into the &quot;weather resistant&quot; : fittings used by Dodge. 1693 is simply a companion fault code to the 0500 had been set in the ECM.
Rod
Old Nov 2, 2002 | 05:30 AM
Ballbearing's Avatar
I don't have any modifications on my 2002 and have these two codes. ???
Old Nov 2, 2002 | 12:39 PM
You really don't need to do any mods to get these codes, all it takes is a loose connector.<br><br>It usually happens after putting in an EZ as you disconnect the connectors, probably loosening them a bit.<br><br>Double check all connectors under the hood, apply dielectric grease to any suspected loose ones, and take the truck to autozone to have the codes cleared.<br><br><br>phox
Old Nov 2, 2002 | 05:12 PM
scottrod's Avatar
Well, I disconnected my batteries for about 20 minutes, hooked em up and drove to work and back. Codes are gone ;D. I appreciate the info. Sure isn't as much fun to drive without the box though [undecided]
Now if I could just get ahold of that blue sheep guy
Where are ya Rod? Hot date with Baaaaaaaabbbbbbbsssssss
In retrospect............. prolly shoulda waited for an exact price quote first...... price first, goof on later..........
LongBlackRam
Jan 8, 2009 07:58 PM
1BAD4X4
Dec 19, 2007 08:08 PM
ksnappy
Feb 3, 2007 02:22 PM
Gambino-01
Apr 8, 2006 11:42 AM
Lrdchaos
Mar 18, 2004 10:00 PM
