code 1693 1688
Old Jan 14, 2007 | 06:45 PM
bill moore's Avatar
code 1693 1688
So my truck has all the symptoms of a bad vp44. I used a OBD2 scanner on it and got the 1693 and 1688 code. From what I understand the 1693 just means that there is anther code (1688). Someone suggested to me that my computer may be giving false codes? Does anyone think that I might be wasting my money by putting a new injector pump in it. I took it to a cummins dealer but was told that I am better off going to a dodge dealer I just want to be sure before I fork out the cash. Thanks for the input I will not be able to read responses after Jan 16 as I will be out of town.
Old Jan 14, 2007 | 07:00 PM
crobtex's Avatar
Be optomistic.............
Before I dropped the $$ for a new VP, I would reset the codes and see what happens. I don't know about false codes, but after all, it is a computer and we know how temperamental they can sometimes be.
Old Jan 14, 2007 | 07:30 PM
bill moore's Avatar
Thanks, ya I erased the codes before I went to work and in the 20 min. trip they came back
Old Jan 15, 2007 | 03:34 AM
crobtex's Avatar
Sorry to hear that.
Old Jan 15, 2007 | 08:58 AM
Truckman's Avatar
Question What symptoms you gettin?
Sure its not something else?
Old Jan 15, 2007 | 04:29 PM
bill moore's Avatar
The main problem is that I have no power, it won't maintain 70 mph up a hill empty. I get a dead pedal a lot and it starts rough when it is cold (this just started happening) I tried going over a small curb yesterday and it did not want to do that. I am going to take it to the dealer tomorrow just for them to diagnose it as a second opinion.
Old Jan 15, 2007 | 04:46 PM
blackdiesel's Avatar
Registered
its your vp. the 1688 is the TRUE death code. your gunna have to replace it. and i would NOT take it to the dealer. its a simple swap that you can do in four to five hours in your driveway. as a matter of fact, im heading up to the shop to replace one right now....
Old Jan 19, 2007 | 12:22 PM
bill moore's Avatar
Thanks for the info. Just a bit to late took it to the dealer it is the VP I guess I was just trying to avoid the inevitable. Now decidind wether to buy one locally or buy one from blue chip (the $1900 one) or .......?
Old Jan 21, 2007 | 10:22 PM
jyates's Avatar
The 1688 code means your VP44 internal electronics has failed.
Several palces to get good rebuilds. for good price.
http://www.hoeslidiesel.com/specials.htm
Hoesli Diesel doesn't charge a core charge if you return the old pump within 30 days. Thay also provide a UPS pickup tag in the box so don't need to pay return shipping for your old pump.
Old Jan 22, 2007 | 09:52 AM
bill moore's Avatar
I orderd a pump from midwest fuel injection. I figure since I get so much info off this site I had better support the people that make it free.UPS just called me so it should be here tomorrow going to change it in a buddies garage since I am away from home. Cant wait to see how it drives.
Old Jan 22, 2007 | 10:43 PM
crobtex's Avatar
Glad your getting it fixed. I hope all works out OK.
Old Jan 22, 2007 | 11:52 PM
1-5-3-6-2-4's Avatar
No, P0216 is Injection pump electronic timeing failure. Mine had that for months and I had to change it this Sat afternoon finally.
P1688 is a much more fatal code for the VP44, hard part failure IIRC
Old Oct 14, 2007 | 06:52 PM
Hrshoes's Avatar
Working on an '00 w/ the same codes, have to the injectors when rolling over and will some what run with battery charger on it, take off charger and quits running, and also was told that the electronic part of the IP could be replaced, but what I've read here it is not the case.
Old Oct 14, 2007 | 11:12 PM
johnh's Avatar
you had better read up on the codes
P1688 Internal Fuel Injection Pump Controller Failure
1965427AC
Nov 28, 2008 06:24 PM
GSP
Sep 13, 2008 07:40 AM
shortkid
Mar 7, 2008 06:54 PM
va dodge
Jul 17, 2006 11:41 PM
jt_gladstone
Aug 9, 2005 11:24 AM
