Clutch Q's
Clutch Q's
I have a 2000 with NV4500, Edge comp box and 100hp injectors. The last time my clutch went out I spent $900 on a ZOOM clutch. I've hated it from the first day. The whole truck shakes when you leave from a dead stop. Now it's 2 1/2 years later and it's slipping while towing. Time for a new clutch. What I'm looking for is a clutch that won't shake my teeth out and has the feel of a stock clutch when leaving from a dead stop, but will hold up to towing. Can you guys please help me out. I don't want to flush more money down the drain. Will a Luk HD clutch hold up?
i would most deff recomend a southbend clutch i have a couple of friends that baught one and have been realy impressed i am tryen to convince the wife to let me break down and buy one my self personaly i think the
South Bend Dyna Max 13" Upgrade Clutch Kit MU 13-1.25 Con FE (Incl. Flywheel)
should be a very good clutch it is rated up to 550 hp and 1100 lbs torque
The clutch chatter is from the flywheel not being turned when they installed the new clutch. Be sure this is done when you replace yours. I have a Southbend Con ofe which is a very good clutch but my installer did not turn the flywheel and even after 2 years the clutch chatter is very annoying but better now than used to be.
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
kwhite4
May 9, 2005 03:22 PM
