Clutch for pulling & street use?
Correct me if I'm wrong, but I believe getblown5.9 has, or had a 3850 in his truck, making well over 550hp, and I've watched him pull a few times, and trust me, he abuses that clutch
I've never heard him mention on here that he had any problems with it holding up.
I'm only planning on between 500-550hp someday, and might try sled pulling a few times, but not much. I think I'm gonna go with a 3850 just to be on the safe side.
I've never heard him mention on here that he had any problems with it holding up.I'm only planning on between 500-550hp someday, and might try sled pulling a few times, but not much. I think I'm gonna go with a 3850 just to be on the safe side.
If I'm gonna spend $1800 on a clutch I would like it to last 3-4 years. I'm only trying for 500hp max anyway. And like JLent when the sled starts moving I let the clutch all the way out and flatfoot it. I got 12 pulls on a $300 Luks clutch thats still going. But I know that it wont hold when I do my upgrades. I just want to do this right once and not have to worry about the clutch for a while.
I hold my throttle to the floor the whole time that I pull. Just feather the clutch until I see the boost peg & the load starts moving & dump it. I can't tell a difference in the clutch since it was new. Most guys just ride them for to long & burn them up, that is why some guys can put a 3850 DD in & only get 20 hooks, but another guy gets 50 hooks.
At 500hp (eventually) and 20+ hooks a year, you'll be looking at rebuilding a DD every year or so. You need a 3850 DD for that. You have to ride the clutch some if you want to be competitive at least around here.
That was my problem at the end of the year. At 500-550 hp pulling 4th lo and 2nd hi I just give the clutch long enough to let the tires turn maybe one time and then drop it, but the throttle is to the floor from start to end. I gave peter 1200 dollars to rebuild my 3250 to a 3850 full feramic pulling clutch. I could slip the clutch after probably 4-6 pulls. Took it out and it was to late, pads were done cracked and falling apart.
That is the safest route for pulling, but my bro has a 3600DD & his clutch will hurt your leg in stop & go traffic. He was snow plowing with it today & had to take a break because the clutch was putting a hurting on his leg. He is a 280lb. guy. That is the only reason that I prefer the lighter pedal, we work our trucks daily.
The ceramic would be smoother while the feramic will be more grabby, but would handle the heat a bit better. Mines a 3600 12CB and I have to agree with JLent that it can be a chore if you have to stand on it for a while. Since you want to pull I'd say just get the 3850 12FB.
Compared to getting a nv5600 back in, the hydraulics are a piece of cake =P The ones sbc uses are a sealed system so its an easy install.
Dwitt0187
May 7, 2008 01:55 PM
rockjeep73
Competition / Pulls / OffRoad
Jul 24, 2006 09:30 PM
Got Smoke?
Jul 31, 2003 03:57 PM
