Check engine light codes
Old Oct 4, 2004 | 05:15 PM
thesheriff's Avatar
I ran the codes from the check engine light and found: P0401: EGR flow insufficient and P0720: Output speed sensor circuit malfunction. The question I have is whether or not the EGR valve is bad or the hose is clogged? Second, I am a little confused because the book says there is a VSS (vehicle speed sensor) and a Crankshaft/Engine speed sensor. Which one is causing the code? I would assume that the Engine speed sensor is the culprit but I am not sure. Any help is much appreciated.
scottsjeeprolet
Jan 17, 2006 10:26 PM
alltimelow1
Apr 6, 2005 07:28 PM
Jc9995
0
Nov 29, 2004 10:21 AM
Copenhagenjunkie
16
Jul 25, 2003 11:18 PM
Stamey
May 18, 2003 10:15 AM
