Changing lift pump,,,,help`
Old Dec 26, 2006 | 12:32 PM
robert78.5's Avatar
I have installed a electric pump from a Versatile tractor, I fed the power direct from battery, leaving my original connector open, I left the original pump off. Now truck won't fire up, no fuel at high pressure lines. I have about 14 lbs pressure on gauge at lift. Would leaving my original connector open cause the engine to think there is no fuel therefore not turning on the high pressure pump?
Old Dec 27, 2006 | 09:17 AM
farmer dave's Avatar
The engine will try to start even if there isn't enough fuel pressure, that is why the ip could go out if the fp is bad. I have no clue how to solve you problem though.
Old Dec 27, 2006 | 11:00 AM
Ram1999's Avatar
Why not power the pump from the original connector???
Old Dec 27, 2006 | 11:04 AM
kuhkuhkyle's Avatar
So there isnt any fuel at the HP lines, but 14 psi at the pump? Is there any fuel at the HP lines while cranking?
Old Dec 27, 2006 | 11:15 AM
HotRod82's Avatar
Did you crack open the HP lines to get the air out of the system?
Old Dec 27, 2006 | 03:59 PM
robert78.5's Avatar
Yes, thanks to all, I had to loosen 3 main lines than she started to poof in the exhaust, tightened them up and off she roared. It will run with the original wire harness unplugged, but my cheap fix did not work. only 5 lbs pressure and about 3 when at 2000 rpm. I ordered the original from Cummins today, might as well keep it stock.
Old Dec 27, 2006 | 06:54 PM
TNfarmboy's Avatar
The last sentence"might as well keep it stock" is not necessarily such a grand idea. These "stock" lift pumps have a rather poor track record.
Txwelder
Nov 26, 2025 01:53 AM
leeboy
Nov 28, 2008 02:01 PM
Txwelder
May 19, 2005 06:10 PM
bkay
Nov 6, 2003 10:39 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
