Can't seem to get it figured out!!! Check engine light came on!
Old Jul 30, 2008 | 11:34 PM
bluemaxhd's Avatar
Exclamation Can't seem to get it figured out!!! Check engine light came on!
Hey guys this thing is about to drive me nuts. Got some of my problems resolved then on my way back to work tonight it started doing that huckle buck junk. Checked my codes and they were 0743, 0122, 0753, 1765, and 1693 none which appeared in the computer codes wiki. It has started back as you are riding down the road the TC keeps locking in and out. But if I lock up the TC it goes away, don't really know if thats what set my check engine light off? Any help would be greatly appreciated. Thanks guys.
Old Jul 31, 2008 | 12:09 AM
Thundercraft's Avatar
These codes are actually from a PT Cruiser site - but it's Chrysler and they are almost the same vehicle anyway
I'm thinking that the codes have to be standard....
And by the looks of things, these descriptions seem to go with your problem.
743 Torque converter clutch (part throttle unlock) solenoid circuit problem - shift solenoid C electrical fault
122 Throttle position sensor voltage low
753 Overdrive solenoid control circuit problem (transmission relay circuit in Jeep RE transmissions.)
1765 Open or short in the Transmission Relay control circuit.
1693 The companion engine control module has shown a fault.
Old Jul 31, 2008 | 01:44 AM
bluemaxhd's Avatar
Thanks I'll see what turns out on those in the morning and see what I can figure out.
Old Jul 31, 2008 | 06:49 PM
WestTN's Avatar
0743 TCC Solenoid/Trans Relay Circuits
0122 APPS Signal voltage too low
0753 Trnas 3-4 Shift Solenoid/Trans Relay Circuits
1693 DTC set in PCM or ECM
These are Diesel Ram codes.
It sounds more like a wiring problem. I think the solenoids are on a circuit board attached to the valve body inside thye trans.
cawt0123
Sep 17, 2006 01:18 PM
scarecrow
Dec 24, 2005 12:25 PM
STANGGT40
19
Dec 2, 2005 07:38 PM
javamann
Aug 17, 2004 08:56 PM
Pureliving
Mar 8, 2004 04:30 PM
