Can someone explain this to me?
Old Mar 20, 2007 | 05:36 AM
airplaneman00's Avatar
OK, I have had the surging thing a thousand times now. Everytime I clean my battery terminals and cable connections it goes away. For about a week. Why does this only last a week? It does work though. Should I replace my batteries? What can I really do to make it go away? thanks
steve
Old Mar 20, 2007 | 08:29 AM
Ryan Hyatt's Avatar
Check the fuses man.
Old Mar 20, 2007 | 06:14 PM
phox_mulder's Avatar
Check the main grounds as well, PCM/ECM ground in particular.
Wouldn't hurt to have the batteries load checked, most auto parts houses will do it for free.
phox
Old Mar 20, 2007 | 06:31 PM
Grider Pirate's Avatar
I had the same problem, over and over, just like you. There is a connector for a single heavy wire (I don't remember if it was a ground or hot wire) just about under the right side battery holder. Once I removed the connector and spliced the wires the problem went away and never returned.
Good luck.
Jim
'99 2WD - 140,000 miles - bone stock. Used mostly for towing my GLIDER trailer!
calls
Jul 12, 2004 06:51 AM
Commatoze
May 25, 2004 12:25 PM
calls
May 5, 2004 10:17 AM
dcwm
Aug 21, 2003 10:03 AM
dcwm
28
May 14, 2003 02:42 PM
