Campaign LP already dying...
Old Aug 16, 2006 | 10:42 PM
Mopar1973man's Avatar
Originally Posted by HOHN
Actually, the voltage to the LP is constant, because lower voltage can cause the motor to overheat.
The ECM uses pulse width modulation (PWM) to slow the pump only during starting. Otherwise it runs all the time wide open.
Looking at a Walbro myself....
JH
HOHN... Your right... sometimes when you do the starter bump you get a pulse and a pause then pulse then stopped... Which happens to be the PWM that you talk about. But normally I can hear my LP buzzing away under the cab... So I know that the LP is getting solid 13-14 volts during engine run time. Other than that you would see up and down fuel pressure that were very wild to say the least...
Old Aug 20, 2006 | 07:17 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Guys Iam lost tryin to figure every thing out and keep my ducks all in a row I want to update my lift pump to something a little more solid than the factory one that is working just fine and will keep as a spare but that being said I am not at the point were i want to do any thing from the tank back yet but I guess I am not seeing clear how a say a holley blue bolts right were the factory goes i can fathom how the fuel bowl for the filter goes back on i mean is it as simple as it look and iam over thinking it any help would be nice thanks though in advanced
Old Aug 20, 2006 | 08:04 PM
TNfarmboy's Avatar
I don't think the are physically putting the Holley blue in the old LP mount. Instead they are mounting it to the frame and splicing it into the old tank to pump line. I changed to a Walbro from Glacier Diesel, but my LP was dead.
Old Aug 22, 2006 | 05:11 PM
Originally Posted by andrew2910
how much oil do you add to a tank??
1 Quart of 2-cycle oil for every 20-25 gallons pumped in...
Old Aug 22, 2006 | 05:36 PM
GSP's Avatar
GSP
How are the Walbro's working out? Are you eliminating the stock LP and just running a Walbro? Where ya mounting it at?
Rick
Old Aug 22, 2006 | 05:57 PM
With any pump I would highly suggest that you mount at close to the fuel tank as possible... This will relief the pump of the stress of trying to pull the fuel...
Hence the name of a pusher pump is created... Basically you can take a stock LP pump and move it the fuel tank and now you got a pusher pump...
dingoe
26
Nov 12, 2006 11:28 PM
CSAGrey1
Sep 22, 2006 07:51 PM
Jim Dynomite
Aug 3, 2006 09:53 AM
AlbertaBear
Feb 6, 2004 06:29 AM
