boost leak
Old Mar 18, 2004 | 11:51 AM
Borush's Avatar
I made a couple of plugs from 3" pipe with one end capped off. On one of the plugs I have a quick-connect air fitting. With one plug at the installed at the boot just past the turbo and the other one on the boot that goes on at the intake horn, the system can be pressurized with regulated shop air. You can then use soapy water on all the connections and the intercooler to check for leaks. This method works good for finding pesky leaks that might only occur at higher boost levels.
Boyd.
Old Mar 18, 2004 | 11:46 PM
Smkndzl's Avatar
boost
here is what I do , disconnect the air inlet to turbo hose and fabricate a pipe and fitting for shop air to hook up right to the turbo , use a air regulator , and pressurize the system , you will be able to tell the difference in sound of the air leaking thru the intake valves in the engine , now use soap and water spray bottle and spray all your CAC connection and CAC , also listen to the waste gate for leaks also .
superdiesel9
Oct 25, 2009 07:56 PM
Common
May 23, 2008 05:05 PM
donhov
26
Jan 6, 2006 07:29 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
Lightman
16
Jan 21, 2004 10:46 PM
