boost elbow ?
boost elbow ?
Hi I was digging through the glovebox, and found the L shaped bleed off elbow that came with my old superchip plug-in box, which I am still using, my question is I know what is purpose is but i didn't use it because I have a metal line where it goes and the instructions said that was because it was an automatic, and I wasn't supposed to use it, but
I have a friend who has a rubber line in this spot (between the turbo and wastegate) and his is an automatic also,
now i would like to use this to see if it gives me any more power, what do you guys think is it worth the trouble if cutting the metal line to fit this in
Don't cut the line, search j-hook or turnbuckle. You can use a turnbuckle and manually close the WG or get a j-hook to allow the wg to open at about ~25-30 psi and yes it does help with a box.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
