Boost ???
Old Jan 24, 2005 | 01:22 AM
Ritler's Avatar
Boost ???
What is typical boost to see out of a 01 Cummins with auto. Banks high ram intake and 4" exhaust. I see a max of 17lbs with or without "EZ" Edge chip.
Old Jan 24, 2005 | 06:42 AM
Tazman's Avatar
Sounds low.
Stock is limited to 21 psi, the EZ can take that up to around 30 psi
Old Jan 24, 2005 | 08:44 AM
RowJ's Avatar
Sounds like an air leak. As stated, you should see 20-23 psi stock. With EZ's boost fooler and disabled wastegate you should be at least 30. Is there any difference in power or smoke with EZ?
RJ
Old Jan 24, 2005 | 10:39 AM
cumminsboy's Avatar
Mine bone stock will reach about 21-22. cumminsboy
Old Jan 24, 2005 | 11:39 AM
ratsun's Avatar
Perhaps a little low IF you dont have a boost fooler. I think with the boost fooler you should be around 30 and 18-21without depending on your gauge.
Old Jan 24, 2005 | 08:00 PM
Ritler's Avatar
It runs much better with the chip in. With chip out fuel economy sucks. 10mpg with sled bed. Were is the most common place for a air leak?? Is there any way to make the wastegate open at more boost????
Old Jan 24, 2005 | 08:38 PM
jrs_dodge_diesel's Avatar
Common places are the flex boots. There are 4 of them. One coming off of the turbo, one on each side of the intercooler, and one attached to the intake horn. The most coommon one for leaking is the lower left boot. Sometimes it rubs on something nearby and it can leak if it wears through. A not so common leak is the intercooler itself.
Old Jan 25, 2005 | 12:38 PM
RowJ's Avatar
Ritler
You have a hardline wastegate, I believe. Have you closed it off so it does not engage, so you can get max boost?
RJ
Old Jan 25, 2005 | 02:27 PM
Ritler's Avatar
Yes its a hardline. How do I block it off????
Old Jan 25, 2005 | 03:12 PM
RowJ's Avatar
Do a search...lots of info.
You can start here...
https://www.dieseltruckresource.com/...ght=turnbuckle
This picture is off Edge's Web Site...
https://www.dieseltruckresource.com/...&postid=385507
Searches take some time..but its all part of the education. They are your best friend..once you get use to them. Even reading what you aren't looking for(right now) is good knowledge for future.
Also, Put truck description in Signature (User CP...Edit Profile...Signature). Lets everyone know what you have so you end up with better answers.
Good Luck RJ
Old Jan 25, 2005 | 05:31 PM
Ritler's Avatar
can u put a spring on it instead of the turnbuckle so it just opens alittle. Say adjust to get 23-24lbs of boost.
Edit: Also what is max you want to see for EGT temp. MIne is installed on the manifold before the turbo.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
