Blowing 30 amp starter fuse again!!
Old Jun 1, 2010 | 04:08 PM
DieselNomad's Avatar
well fellas, i did a search on here for this very same issue for the father in laws truck.the search indicated a faulty starter.so he had a mechanic friend of his check it out and he changed the starter after his testing showed it to be the problam.well today mother in law calls and says the truck is dead, yup yoou guessed it the 30 amp fuse was burnt.so now were to start to look at wireing issues.
Old Jun 1, 2010 | 04:21 PM
1-2-3's Avatar
Just a plain ole guy
What about bad solenoid contacts?
Old Jun 1, 2010 | 04:34 PM
would that still be the case with a new starter installed?
Old Jun 2, 2010 | 11:23 AM
1-2-3's Avatar
isn't the solenoids separate from the starter?
Old Jun 2, 2010 | 11:52 AM
welder 59's Avatar
The switch on a Denso starter is part of the drive end housing assembly. You change the starter, you change the contacts also.
Old Jun 2, 2010 | 11:54 AM
JD730's Avatar
Check the condition of the big wiring going to the starter, I had the end corrode off of mine and it was doing the same thing you describe.
Old Jun 2, 2010 | 11:57 AM
welder 59's Avatar
Ya, sounds like wiring to me.
leftturn7m
May 13, 2014 03:43 PM
JPR Ram
May 28, 2007 10:16 PM
T398
Jul 29, 2006 09:04 PM
WS6HUMMER
Mar 10, 2006 10:52 AM
storx
Aug 24, 2005 07:37 AM
