which block do i have
Old Jan 23, 2007 | 08:41 PM
crispy89t's Avatar
i've been reading alot about blocks cracking? where do i check to see what block i have or what years did they switch i've got a 99 3500 with about 181k. and i'm just wondering if i should be worried about my block cracking
Old Jan 23, 2007 | 09:08 PM
Tate's Avatar
Being a 99, chances are you have a 53 block. Check on the front of the engine, driverside, just above the oil pan. Should you worry? IMO, no. If its going crack, its going crack, regardless if you fret about it, or just carry on with life. The amount of 53 failures are pretty low. Its just that when one happens, everyone hears about it.
Old Jan 23, 2007 | 09:13 PM
crispy89t's Avatar
what happens when it cracks? loses oil pressure or what? i'vd got alittle bit of an oil leak i always thought it to be my breather hose because most of the oil starts in that general area
Old Jan 23, 2007 | 09:16 PM
Tate's Avatar
It leaks coolant out the side of the block. On the passenger side, in the middle of the block. Crack goes horizontally, somewhere between 2-8" long.
Old Jan 23, 2007 | 09:17 PM
crispy89t's Avatar
no problem thanks
Old Jan 23, 2007 | 10:05 PM
bumpytruck's Avatar
Here you go ,alot of information here. http://www.cumminsdatabase.com/read.php?id=185
Bradleysram
19
May 12, 2009 08:36 AM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
