Belzona 1111 Super Metal - 53 Block solution?
been reading a lot of positive reviews about this commercial grade epoxy, it would not surprise me in the least if this product would patch and hold for a very long time on the dreaded cracked 53 block.
just thought i would put this idea out there for feed back.
http://www.youtube.com/watch?v=7zErQrkIU9I
http://www.belzona.com/
Belzona Super Metal (1111) is the absolute best for engine block
repairs.
Caterpillar specifies Belzona for engine repairs.
Belzona does not rot, shrink, or corrode. Other products, when tested
in the exact same tests, all have lower mechanical properties.
If you are after good long term results, the Belzona products are very
inexpensive.
repairs.
inexpensive.
I work at a refinery and we use Belzona to repair certain pieces of equipment. If it is good enough for use here it will probably do a heck of a job on these blocks. I have a contact with Belzona if we want to ask any questions.
did a search with "belzona" found a few reports of this stuff...
also read one where the guy drills and taps a plate over the crack, after drilling the ends of the crack to stop it from spreading, I think this would be the route I would try if my 53 block every dies
https://www.dieseltruckresource.com/...archid=3883441
for someone that looked into this product..what are the temperature ranges??
when does it soften..all epoxies will??
i'm not against this product just wondering..
I use lots of the other epoxies for other things..
-dkenny
-dkenny
I would take this post in to consideration, I would have trouble believing it would hold up to the heat cycles, we just talked about this in my Engineering Materials Class last week.
mattmanj2001
Aug 19, 2010 08:18 PM
VikingDiesel
Nov 6, 2006 01:12 PM
5string
35
Jul 29, 2006 11:14 PM
Strjock81
Jan 13, 2005 09:16 AM
