Battery drainage issue.
Old Aug 12, 2009 | 02:40 PM
77machomopar's Avatar
Electricity is not my strong point at all. On my '99 the batteries are being drained over night. So what is the most common problem with these trucks that drain the batteries. Also whats the easiest way to troubleshoot the issue. I already load tested both of them and they are still in good condition. thanks
Old Aug 12, 2009 | 03:26 PM
dozer12216's Avatar
Look for simple things like glove box light on, or cell phone charger left in socket. How about a add on accessory wired direct?
The next step would be current draw test. Hook amp meter between positive cable and post. Take bat cable off other battery. Remove fuses until amperage draw is eliminated. Track out offending circuit.
Old Aug 12, 2009 | 05:36 PM
Ill do the current draw test. it has no aftermarket accessories on it. Ill check the glove box door also. thanks
Old Aug 12, 2009 | 06:55 PM
bent valves's Avatar
Don’t forget to wait for the seatbelt timer. After you close all doors, the seatbelts will draw current for about 15 minutes. The best way to make the current test is to roll down a window, close door, and test the seatbelt for free play. If it is loose, the computer will still be drawing current. If it is not free the timer has shut off and is not drawing current.
I had that seatbelt timer fail and never stop drawing battery current. The seat belt was always free to pull out of the seat back.
Old Aug 12, 2009 | 07:31 PM
Thanks i will have to look into that also.
Old Aug 13, 2009 | 09:02 AM
The seat belt timer. After 15 min. i shouldnt be able to pull out the seat belt correct. I tried it with the window down and 20 min later i could pull it out.
Old Aug 13, 2009 | 08:33 PM
OK well they pull out of the seat after 2 hrs. So what should i do to fix them?
Old Aug 13, 2009 | 08:43 PM
digbog's Avatar
I think your belts are supposed to pull out under normal driving conditions. They lock up when it is jarred or pulled fast.
Old Aug 13, 2009 | 11:21 PM
dozer12216's Avatar
Yes, seat belt pulling out is not your issue.
Old Aug 14, 2009 | 06:15 PM
I will try the dealership but i doubt they will come through on it. Ill try cleanings the connections and see what happens
Chrisreyn
May 14, 2013 09:15 PM
extremeshot
May 31, 2010 11:44 AM
redpoint5
May 16, 2007 07:52 AM
planejane
Aug 23, 2004 03:17 PM
doodah
Feb 12, 2003 07:57 PM
