Battery connection question
Old Aug 13, 2009 | 03:24 PM
KenC's Avatar
I have been having issues with my tranny shifting in and out of OD for the last month or so. I cleaned contacts on my batteries and found the tranny shifting better but still not correct.
I disconnected both negative cables from the batteries to reset controls and I noticed that the under hood light stayed on. Opened the drivers door and found the same issue.
Is this normal?
I didn't think the batteries should ground through the case.
Thanks for any input.
Ken
Old Aug 13, 2009 | 03:30 PM
rednekroper05's Avatar
i wouldnt think that your batteries should be grouned through your case. Try taking the neg. cables off then turning your key to run postion if anything comes on then your batteries are gounding through your box.
Old Aug 13, 2009 | 03:59 PM
KenC's Avatar
Nevermind, Found the problem.
Hooked up to my car trailer and the emergency brake battery is back feeding to the truck. Pull the trailer plug and lights go out.
Old Aug 13, 2009 | 04:08 PM
ha ha done something similar before backed up a trailer to a electic fence and the couldnt figure out why the truck would quit shocking me.
WesHawkins
18
May 11, 2020 07:41 PM
FishingFather
Sep 25, 2009 06:51 AM
MLRey
Jan 17, 2008 07:42 AM
bugdug97
Jun 20, 2005 07:09 AM
planejane
Aug 23, 2004 03:17 PM
